SXR wiring problem
masshole
reassebling my sxr and Am i missing a connection on hooking up my ebox?
I have Ebox to (+) on battery
(-) on battery to ground on engine block behind starter
Ebox to Starter
stator to Ebox
start/stop switch to ebox
but when everything is hooked up i hit start I get nothing, only ebox, battery and motor is dropped in right now
masshole
i have my tester on the wire going to the battery and i hit start it reads nothing same with when my tester is on the wire to the starter
OCD Solutions
Rentz, GA
Charge your battery, double check your grounds.
Did you happen to spin one of your battery connections and break it loose? Is it reading at least 12.6V?
