3m makes a product, Kawi actually uses them to mount to the sides of ski's when running wiring and hoses............ you would need to remove the double sided tape and then glue it to the hull............ these are little square pcs about 1" square that you run a zip tie through it...........
Used for routing wiring and cables.....
