Winterizing and flush kit.
MI
Anyone know what you can do for a flush kit that you can run antifreeze through for winterization also.I have a newer superjet. I was wondering if I could hook up a hose to the little screw near the bottom of the pipe( if you guys know what I'm talking about). I really don't want to do use a backflush or cut the Intake line and install a t fitting. Any help is appreciated
john zigler
Vendor Account
wisconsin
No need for antifreeze. Your engine will self drain.
I take the hose off from the head, to pipe. Using the air compressor blow all water out backwards through the head, and hose going to the exhaust pipe. Do this while the engine is running, and blipping the throttle to blow out the exh water box.
Fog with fogging oil to kill.
Remove battery, and you are good to go.
