Super Jet Will v-force 3 reed cages work with any 62t manifold??
rubbertoe
X-H20 certified
San Diego
just wondering how many people a re running the v-force set up ? and how do you like it ? will they fit a 2 pc manifold? with my single carb 46mm my manifold i believe is made by riva and its two peice[plate/manifold],any issues?i am new to the yami's.im looking to get a little more low end hit out of my 785 it feels as if my boats jetted well just wondering if theres a little more low end to tap into by running these?and also does anyone have any jetting advice,one richer on the jets ,or will it be close enough not to change anything? thanks in advance ,robert
rubbertoe
X-H20 certified
San Diego
c,mon i need something to ponder till these things are installed.im sure i can figure it out but why chance the learning curve...
D-Roc
I forgot!
i got them, they are nice, i had that same single intake before but cannot remember if the reeds recess in and around that 2nd piece. i think they do in which case you may be better off with the v-force 2's. the 3's are a plate design that fit in between the cases and the intake. I am using them on a R@D intake that is smooth like the oem intake. i don't use a reed spacer, because its not needed with the 3's.
rubbertoe
X-H20 certified
San Diego
d-roc ,thanks bro! in a nut shell that addressed exactly what i am wondering..i am just not familiar with this style manifold ?
