waxhead
wannabe backflipper
- gold coast
Ok well i used that title to get you but now you are here have a look whats up on the wax bench
We’re currently developing new dome shapes for our upcoming range, and I’ve never quite understood the logic behind a straight squish band on a round-top piston. Our new designs are built for the unleaded fuel era — with improved cooling and properly shaped squish bands for better performance.
The current domes on the market have up to 11 mm of material at their thinnest point, creating an unnecessarily long heat path between the combustion chamber and the water jacket. This excessive thickness causes heat retention, which can actually promote detonation under sustained load. We've addressed this by reducing the wall thickness to 8 mm minimum. While 5 mm is often regarded as the ideal balance between heat transfer and structural strength, we've chosen 8 mm to ensure long-term reliability. The last thing anyone wants is a cracked dome — even years down the track.
Let us know what combustion chamber volumes you’d like to see in the lineup. Keep in mind: when a dome is properly designed, you can safely run higher static compression without detonation
