Freakrider
X247
- Tampa Bay area
Rebuilt a blaster midshaft housing with new oem bearing and seals....installed and tested it without the pump in...the shaft is heating up near the front seal after 40 sec of idle run time...shaft on coupler side is not even warm... this is why I rebuilt it, I thought the bearing was getting hot...is this the friction from the front seal causing the heat ? other skis do not heat up like this ? what is the problem ? thanks for your thoughts.... :261:
