where to buy epoxy mailorder
Where can I buy viynlester resin mailorder. I need to repair my wamilton hood.Wammer said to use viynlester resin because it is easier to work with.Is this good advice
What is the difference between viynleaster polyester and epoxy
extreemthrottle
freeride junkie
north palm beach
i've used this product for years also the dealership that i worked for used to repair huls and anything smc or vinyl. i believe your hood is the same thing as smc. its an epoxy from this company, http://www.winzerusa.com/ they used to make two types. one was 2-3 min work time the other was 8-10 min work time. i have'nt used either in a long while so i don't remember the exact name, but if you tell them what your doing they will steer you in the right direction.. hope this helps..................
