Blaster where to buy 81.5mm piston rings for wiseco's
so i got a big problem i cant find rings for my pistons, got a set of older 81.5mm wiseco's came out of a 1100, putting them in my 701 now, only got 1 ring left and they are nothing like the stock ones they got a big notch cut out in the gap to go around the pin in the ring lands, where can i find these guys i need help please lol
Waternut
Customizing addict
Macon, GA
The older wiseco's used different rings than the new ones. The older style rings are "TD" style and the new ones are "KD" style. I believe the ring set you need is P/N 3209TD but you need to double check that before ordering. Wiseco will sell them directly too but you have to call to order the older style.
Octane_114
LeT tHe gOOd tImEs RoLL
Charleston S.C.
you are correct. those 3209TD 81.5mm .020
