Where is the best/$$ to buy a throttle cable for your sj?
jeckert
Going backwards
Chicago
Where is the cheapest place to buy a throttle cable for your sj?
Retail is like $112, and the best price I can find is $60, but if you need several that adds up pertty quick! I'm looking to spend $30 or less.
Your response is appreciated!
Joe
crammit442
makin' legs
here
Get a Kawasaki cable for a '93 750sx. Better cable all around and is long enough to use for duals reversed( cable pull on rear carb) The threads are 10mm so less likely to strip out and you don't need a throttle adaptor. Retail is less than $40.00 for OEM Kawasaki. Kawasaki part number is: 54012-3732
Charles
Tuscaloosa, AL
Dooooohhhhhhhhhhhhh , anytime someone mentions OEM I spout Greater because John has always been really good to me over the years, I always forget that Paul stocks alot of OEM Parts!!!!!!!!
Sorry Brother........
crammit442
makin' legs
here
unclehulka13 said:
Joe, i've got a kawi cable. I'll let you know if it works when me and keith put your motor in.
What do you mean, IF it works?:wink: That's what I have in my boat right now.
Charles
crammit442
makin' legs
here
unclehulka13 said:
single or dual carbs? Im gonna run a single, hes gonna have duals.
I'm running duals reversed so that the cable bracket is at the rear carb. It's just a bit longer than the square nose cable. More than long enough. Blowsion(Mark) is who suggested it to me. It would work well for a single also. Just have a bit more cable to work with.:smile:
Charles
