Super Jet Where do I tap the pump for dual cooling? '92 SJ
Hey guys, I'm just finishing up my ski and before I laid up the glass in the tray I ran dual 3/8" cooling lines. I'm now stuck as I don't know where to tap the pump for the 2nd line. Both lines come out on the left hand side (where the original was). I have a '92 Superjet and the only options I see are:
#1 to go straight into where the original is and "T" it off into 2 lines.
#2 Drill the original one out bigger and "T" it off?
#3 drill anywhere on the pump (near the original) and put a new fitting in flush with the inside of the pump. This doesn't seem like the best idea, because of the thinner material, but it might work?
I'm at a loss. I had assumed that there would be a slug, or enough material on the other side to drill and tap a new fitting.
anyone done this? Ideas?
There should be a boss on the other side that you can drill and tap for a fitting.
If its a 92 stator section you need to fill the factory siphon hole with a brass slug and JB Weld then tap it for a fitting. Upgrade to a 94+ stator is way easier
