ANT
Just ride
- Sea Isle City, NJ
lets just say i think to much but here it goes:
Watercraft factory top deck/square bottom
re-enforced completely w/ glass and carbon
re-foamed
watercraft factory hood
wf nose piece
wf footholds
wf chinpad
x-metal -2 pole
umi bearing system
x-metal turnplate and bars w/ odi lock on grips
(complete setup is -4 1/2")
x-metal bracket and pole bolts
x-metal hood hooks
x-metal scupper
x-metal waterbox
x-metal pissers
x-metal front exhaust outlet
new short shaft, bearings and housing at beginning of season
new hood seal at beginning of season
new pump seal at beginning of season
new s/s switch at beginning of the season
jet dynamics pump shoe
skat trak 12/17 prop
tbm super pump cone
daul cooling
daul single oem 44 flame arrestors
daul oem 44mm carbs w/ intake crossover blocked off and primer
reed spacer
proX .5 over pistons
LPW freeride porting
ADA girlded head w/33cc domes 190lbs runs on pump gas
LPW lightened flywheel
MSD enhancer
Factory B-Pipe w/ mod chamber
jet works flow control valve
blowsion daul internal fuel filler
daul 500 gph rule bilge pumps w/ rotary switch
rails turfed with black molded HT
tray and gunwales turfed w black molded HT
ski is gelcoat white in excellent condition
it's not for sale but i just want to get an idea incase sometime in the future i decide to.
re-foamed
wf nose piece
wf footholds
wf chinpad
x-metal -2 pole
umi bearing system
x-metal hood hooks
x-metal scupper
x-metal waterbox
x-metal pissers
tbm super pump cone
daul cooling
reed spacer
MSD enhancer
