2lick
Brap!!!
- Limerick, PA
OEM one took a poop.
I hoped on atlanticjetsports and was going to order one of the TDRs... anyone run one of these or is there another one you'd recommend. I have a basic 701, high compression, bpipe setup and don't plan anything else.
Fits: Yamaha WaveBlaster 701 1993-96 using Factory Pipe exhaust system. This waterbox has 30% more back pressure (flow restriction) to match the Factory Pipe brand exhaust system.
Complete Part Number:
TDR Silencer Baffle Style Waterbox: The Baffle type waterbox is designed for the recreational rider who wants a power increase with a deep throaty sound. This box works well with stock and slightly modified engines. Although the baffle type waterbox is louder than the stock “OEM” waterbox, it is not offensively loud and it is the easiest to install.
TDR Silencer Power Spray Style Waterbox: The Power Spray type waterbox is designed for the recreational rider or racer who wants the maximum power increase with a deep throaty sound. This box works well with modified engines. The TDR “Power Spray” waterbox is completely hollow and has no restrictive baffles, allowing maximum exhaust flow. The “Power Spray” silences the exhaust noise by inducing a series of ultra-fine sprays of water mist. This mist of water applied in the proper places slightly quiets the exhaust noise without any restrictions or power loss. WARNING: This waterbox is extremely loud and could result in fines for excessive noise.
These waterboxes are made to order and take 1 to 2 weeks for production time. If you are unsure that you are ordering the correct waterbox please contact us as the older models are custom made and are not returnable. Installation of a TDR waterbox may require jetting and / or impeller changes due to the increase in exhaust flow and horsepower.
- Baffle Style: 02-0014-B-FP
- Power Spray Style: 02-0014-PS-FP
