- Ocala, FL
When I rebuilt my motor a year or two ago I snapped one of the bolts for the flywheel cover off. I drilled it out a bit and went at it with an easy out and ended up snapping it off inside the bolt. I grabbed another easy out and tried ago.
Now I have an easy out stuck inside of an easy out stuck inside of a bolt stuck inside of the hole....
I just used a lot of the gasket sealer around the whole and it has been fine since (from what I can tell) but Ill probably be replacing the flywheel and bendix this year and I though about getting a billet cover with an o-ring instead of the gasket. If I go that route I definitely want to fix the bolt properly.
Which methods would you guys recommend? The cases have a tiny bit of internal damage from when my crank bearing shredded itself so spending a ton of money getting it fixed might not be worth it, although the damage is almost entirely cosmetic.
If it makes a difference its a 61x
edit: also, instead of starting a new thread to ask this, does anyone know which sit downs share parts with Superjets/FX1s? Mainly looking to pickup a 701 and maybe pump for spare parts if I ever see a cheap sitdown on CL.
