What spark plugs?
ToddW
Web GuY
Folsom Lake - CA
I'm wondering what would be the proper spark plugs, and gap for my engine:
701, mild port job, dual 44s, b pipe, 165psi in each (still
have to re-test but in that region),
Thanks
-Todd
keefer
T1
Tennessee
What head are you running? If it is stock you have to run the "H" series short thread plugs. Most run BR8HS or B8HS on stock heads. Most all aftermarket heads take the long thread "E" series plugs, BR8ES or B8ES. Usually the gap is about .028 to .030
keefer
T1
Tennessee
Run BR8ES if you have the stock or MSD plug caps. If you have the NGK resistor caps then run the B8ES. The resistor will cut down on RFI that can interfere with digital ignitions and other electronic devices that may be near you.
