650/X-2 What Is this?
Joker
...chaos? Its Fair!
What is this? I got it in a box of parts when I bought some 300sx hulls. I have seen guys with the power factor pipes have something similar to this.
Please disregard the other pictures lol. Tapatalk does weird things. I'm jut referring to the white box thing.
I'm thinking about modifying it to fit my 650 cause the other one weighs like 100lbs
:/ it is better to run a stock drilled waterbox than modifying that to fit your ski (save your time and money on something else)
If you want a light weight waterbox and dont mind the ring in your ears in a couple of minute of riding then get a aftermarket waterbox
dfw
You will need the weight up front if you are above average height/weight. If you are little then find a Mariner box and mount it on pads made of EVA floor foam, over 5lbs can be saved.
