- US
I pulled this 61x out of a 1994 waverunner 3. I took the motor apart and cleaned everything. I did a complete gasket kit and carb kit. The engine and carb are all stock. Engine has 145 psi in both cylinders (matco tester). Tested stator with snap on ohm meter and factory manual specs.
61x engine
Stator
Starter
Bendix
Flywheel
Mikuni carb
Intake manifold
Factory reeds
Complete factory exhaust
Sent from my Pixel 2 using Tapatalk
61x engine
Stator
Starter
Bendix
Flywheel
Mikuni carb
Intake manifold
Factory reeds
