I'm giving one of the 400 hulls away for free. Arrange pick up and it's yours. The only thing you will get for free is the hull. I will be keeping any and all parts unless you have some $$. If noone wants it, I cut it up and throw it away. I'd rather see an old ski find a home than kill it. Both hulls have damage too them, but you can have either, I don't care. As for the second hull... if I don't get $$ in my hand for pumps and etc... I'm going to cut down the ski to just the jet drive and throw the rest away. I'll mount it in a ganoe or something.
I realize from this point on, I'm probably talking to myself, but meh, I entertain myself.
As for the 650 and the X2s... I'm amused by everything I've got here.
It looks like the X2 with an engine has an aftermarket alum. head, a pipe, intake, ride plate, some K&N stuff, MSD ingnition, and that's just what I found while moving them. Hopefully it's not seized...
The second X2 has a lot of good parts and the hull is in much better condition. If I can get the engine running, I'll be using this hull. It also has a brand new finger throttle and matching bar mounted bilge switch. The bars and cables look good but I don't think they'll work on my SX. *Edit* oh ya, and this X2 has the start switch that allows for the use of a laynard. I've wanted a laynard so if this is working it'll be $$$$.. This also has an MSD ignition.
The 650 has lots of goodies for no engine. At 1st glance, it has a good throttle cable, the stock bilge, a working fuel toggle, the upper exhaust manifold, good hood seal, all parts I don't have or are borken. The hull is in much better condition than mine so I can rebuild this one and move my engine. With a second hood, i can modify one w/o worry of ruining it. Appears the pump is frozen =( I think the starter that was with it is frozen too, no movey by hand.
I think the X2 and SX use a lot of the same parts, and if that is true, i now have like 16 motor mounts, 4 different ride plates, at least 2 different intake grates.
I know the 650SX and the X2 are practically identical. Can anyone tell me where the differences end? It would seem that the pump, engine, fuel... everything except the hull, bars and cables are the same. I'll research it some later but anyone able to give a few tid bits.
I'm like a kid in a candy store. woo hoo.
