Super Jet What do i need to put an 1100 in a superjet..?
What do i need to put a yamaha 1100 into my round nose superjet? Ive got a complete 1100 motor and a rnsj hull.. i looked for some threads on an 1100 swap and cant seem to find what i need.
- What prop should i run?
- my hull was modded for a front exhaust, will that work..?
- Where do i get a bed plate to swap it?
Any help would be greatly appreciated...
Byeai
"Cheetos-Man"
Melbourne FL
rad dudes has alot
1100blaster.com
u can find the plate on there and shaft
u have to get rear exhaust unless u can maybe get the sxr version but the have ot on the website
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
customride0105
sterling va
I did a Kawi 1100 in a sj hull 08 hull and love it. Can give u step by step...
As I believe I am the only one to cram a Kawi 1100 into a ask hull so far..
its a little harder to do it in a sj hull and exhaust won't fit u have to cut a lot off the camber I got pics of the chamber of what ul have to cut to fit..
Get rid of the ft exhaust... As mines loud as it is with rear exhaust I'd hate to hear it w ft exhaust. Just had mine out in the bay this weekend jumping it and having a BLAST on it..
http://www.pwctoday.com/showthread.php?t=372274
'kotajoe
Do Good Crew!!!!!!
NRH, TX
Extreme Throttle makes the adapter plates to bolt it right in. Ive started this same build but with a square nose. There is a rumor that one of the exhaust hoses from an FX140 makes the 100° bend to get the exhaust routed to the front. A rn exhaust from the waterbox to the back of the hull will provide enough flow but an a/m waterbox and 3" piping to the waterbox from the engine is needed. Ill be making making a build thread when I finish everything.
'kotajoe
Do Good Crew!!!!!!
NRH, TX
The only pipes I have found are those huge three chamber setups that can only fit in a couch. The factory 1100 exhaust flows pretty good from what I have read.
