Super Jet wet jet mani vs. 61x mani
agua
FIshing for Stand ups
Seminole, Fl
I have a wet jet intake and ive heard its better, what makes it better? should i go ahead and put it on my ski when i change my stock carb to the wet jet carb?
dfw
Depends on which WetJet manifold you have. If it looks the same as the one on your Superjet its because it is the same part. The WetJet Kraze manifold takes a unique SBN46. People naturally think its better because its bigger whether it is or not.
baldwin ny
i am in the middle of testing the if this setup works better or not. here what i have. testing on a ported 61x/61x.std bore cylinder. 200 psi compression,b-pipe. msd cdi, boat was running with a set of sre 46 on it. i had my 46 blackjacked . so far it runs pretty good still have to work on jetting some. (got a flat spot in the middle) but if i gave you the ski to ride you would think theres a set of carbs on it not one. i have another stock wet-jet kraze that i am going to put on the ski to see how much better the blackjacked 46 is. all and all i say go for it. (nothing runs as good as a set of dule carbs)
