Super Jet wet jet carb / manifold
agua
FIshing for Stand ups
Seminole, Fl
yesterday i went to put my wetjet carb on my 61x manifold and discovered one reason why people use the wetjet manifold with it... the holes line up...
so i went and dug my manifold off my engine i have in my garage and tore the gasket, is it the same gasket as my 61x? i dont wanna pull my manifold thats on my current set up because i dont wanna tear that one too and be out of the game so ill order one ahead of time if its the same, i went on sbt to look for a gasket and they dont have wetjet listed on there site unless its named something else?
thanks for the help
Brian
58vwragtop
Braap Certified
Blue Springs, MO
Yep, the WetJet manifold uses the stock 61x gasket. Also look at the bolts from the stock manifold, you might want to get some that are about 10mm shorter or use washers. The WetJet manifold mounting flange is thinner than the stock 61x. I tried using the stock bolts and one of them bottomed out and broke in my case. Just thought you might want to look at that too.
