Shrivel
Requires therapy.
- Acworth, GA
So I drop by the lake for a couple hours today before work and put the ski in the water. Basically a stock 701 engine. It cranks fine, but runs really rough at the low end and bogs out on me once I drop to idle speed. Cruising speed it seems okay, maybe a little bad on the throttle response.
So I figure maybe my plugs are fouled, since the last tank of gas was a bit on the rich side, but I've never fouled plugs before. Just to be sure I pull out of the water and pull the plugs and instead of being fouled, it was the exact opposite. They were dry AS A BONE and had a whitish appearance. Definitely not normal.
It seems like I'm not getting enough fuel (and therefore not enough oil), but I'm not sure of the best approach to take to systematically determine where the problem is. If it's a fuel line blockage, where's the most likely place to check? I'd like to avoid breaking too many of the dumb little cable ties on the hoses if possible.
