Hey guys I just rebuilt my engine (new crank, rings, hone, seals, head). I am running into a problem with the compression. I am running an ada head with 37cc domes. The front cylinder is running at 170 psi while the rear cylinder is showing 190. Any clue as to why this is happening? only thing I can think of is a pinched o ring or a dropped sleeve. I have about a tank through the rebuilt engine. I wouldn't be concerned if the numbers were even.
