WB1, noise, lossing power. problem
Sweden
Hi!
I have a WB1 -94
61 X engine
Mikuni super BN 46
Airfilter Blowsion
Boyseen carbon reeds
Nynja C4 pipe
701 rear exhustpipe
MSD coil
MSD Enhanser
TDR water box
solas 14 / 18 prop
SBT wearring
Milled head.
170 / 175 psi
Last year it started to do a short metalic hight pitch nose. Sametimes / often at WOT and shopy water. Sometimes in a holeshot.
Have tryed the following stuff:
The oem wearring had swollod and I changet it to SBT plastic werring.
Rebuild the midshaft with new bearings and seals
Rebuild the pump with new bearings and seals
Lowerd the RPM limit to 7400 rpm
Installed dual cooling
Last ride before i teard the engine apart i moniterd the rpm and speed.
Cold 6400 rpm and 41 knot / 47 mph
Then after 2-3 min it dropt to 5500 rpm and 36 knot / 41 mph
And in the end dropt to 5250 rpm, didnt get a speed. At this time a nose came often.
No vaccum in the fueltank.
Tryed 1/4 turn ritcher, worse speed, stil the nose.
Wen i came back I notice the engine pto was very hot, to hot to hold your hand to.
Now I have teard to engine apart and have maby found something?
The seal surface has a been very hot and changes color.
Is this from the seal o bearing? Have anybody have this kind of problem before?
It starts to get expensive and want to ride!!!
Or is it something else?
With best regards / Christian
From your video that crank main bearing looks ok. Side to side seems fine and it spins freely. Is your pto aligned to your midshaft coupler correctly? Perhaps the alignment is way off causing too much friction in that joint?
That bearing is toast. There shouldn't be any noise coming from it and there is movement. If the others are making noise replace the crank. If its just that one replace it. When you put it back in align/shim the engine.
Sweden
Thanks!
The noise is gone, the power is back and the coupler is not as warm any longer.
The fix:
New main bearing PTO end.
New seals and did a leak down test
Was missing one of the washers (17)
Did align the drivetrain again (needed 0.5 mm more shims to make i perfect).
Dont know witch part that fix it but I´m happy : )
