Wax racing products girdle head
waxhead
wannabe backflipper
gold coast
Available as a Complete Kit or Individual Parts
Whether you're doing a full top-end build or just replacing a component, the Wax Racing head system is available both as a complete kit or individually as separate parts. Choose what suits your build:
  • Purchase the head, domes, and girdle kit together as a full setup
  • Or grab only the components you need—each part is listed separately for maximum flexibility
Product Features
  • CNC-machined from 6061-T6 aluminum for strength and consistency
  • Anodized finish for superior corrosion resistance in saltwater environments
  • Includes brass water fittings and O-rings for all sealing grooves
  • Compatible with ADA-style domes
  • Comes with twice the number of O-rings needed—because we know how easy it is to drop one during assembly (Yes, we work on our own skis too.)
Current Dome Availability
  • Wax Racing currently offers 35cc domes for 701 applications
  • New toroidal-shaped domes are in development to optimize performance on unleaded fuel
Girdle Kit Compatibility
  • Girdle kit fits both 701 and 760 cylinders
  • Note: 760 cylinders will require machining to clear all girdle studs
Spark Plug Info
  • Uses standard-reach NGK ES spark plugs
    • BR8ES or BR9ES depending on your compression and timing setup
    • Use BR9ES for higher compression or more aggressive ignition timing
What’s Included (with head only)
  • 1x Wax Racing billet head
  • Brass water fittings
  • 2x sets of O-rings
To Complete Your Setup
Be sure to add:
  • 2x domes (sold individually)
  • 1x girdle kit (sold separately)
I really like the look of it Waxhead! Sweet looking blue as well, great for those blue yamaha Ski's :)
I will be staying tuned to hear more about your dome development.
