Waveblaster limited pipe carb settings
Kuwait
hi, I am installing a factory limited pipe in my waveblaster and I'm not sure what the correct carb settings for the ski should be. I'm running a waveraider 760 with the stock Yamaha carbs that came with it if that helps. Thank you
Vumad
Super Hero, with a cape!
St. Pete, FL
My superjet with 62t/61 motor and limited SJ FPP is 140/75@42. I'm richer than most recommend so it can load up a little in the surf but doesn't get lean at extended WOT.
Vumad
St. Pete, FL
Sorry, I overlooked the 760 part. I had in my mind a 701T/T so the jetting I said I have is no good for you.
No reason to change out the carbs.
