Waveblaster 2 rough idle when warm
Ohio
Does anyone know where the hose water hookup is on the blaster 2? I figured it would lead to the engine but all i see is a hose coming out of the bottom of the exhaust.
Ohio
There is a hose hookup on the ski that leads to under the driveshaft area behind the motor. Would this feed water through the engine as well as the jet unit?
Swordfish
foolin around
It likely feeds into the exhaust which feeds up through the motor as well and will come out the pisser on the left side of the hull towards the front. I haven't used the hookup in mine but that's usually how it goes as far as I'm aware. It probably doesn't feed into the pump.
