Waveblaster 2, 1100cc conversion.
Hi guys,
This is my first post and I would like to obtain some informative information if possible?
For this initial set up, this motor is stock with level compression throughout all cylinders. No porting and using standard 44mm carbs.
Standard exhaust: Can this be used or does this affect engine performance/HP?
Using 44mm carbs at sea level. What jetting is used?
Prop size / pitch?
If you or anyone you know has this conversion, all or some information will be greatly appreciated.
Mike from Brisbane Australia.
