Thanks, you are correct, I understand that, maybe I phrased my question incorrectly, I'm curious what the voltage output to the battery is on a superjet after it passing thru the reg/rectifier, is it 13 volts, 13.5, 14, 14.5. I am curious if anyone had voltage tested a properly working charging system at idle? I can only test my jet ski running on the lift in the water, and I turned idle up some to get rpms to a faster idle.
I put a fully charged new battery in my Superjet, and the battery was at 13.03 before starting and after starting, I didn't see any change.
