Vapor Lock on a 94 Blaster/Radier?
I have a 94 Blaster and Raider, I need some help with the Raider. I was told that they both have just about the same motor. Last year my Raider would run fine when you first started then in about 5-10 minutes of fill out running it would just die. Just like you hit the kill switch. It might start back up and run for a minute or two but then would die right out and keep doing thid until it run the until you run down the battery. I took it to a shop in the fall of this year. They said it was a vapor line that was collapsed. Which made the engine to stop. Is this true and can someone tell me how to fix it. It is doing the same thing all over.
