The biggest difference between the Delta 2 and Delta 3 is that the new valve has an intake stuffer which smoothes the transmission from the carb to the reed cage. The Delta 2 has an open design. The Delta 2 has reeds retained by screws and a stiffener plate. The Delta 3 valve has "snap" in reeds. The Delta 2 had more top end. The Delta 3 has more off the bottom and still retains the top end advantage of the Delta 2.
