Using 1/2" siphon line as dual cooling???
NY
Has anyone ever swapped the 1/4" cooling line with the 1/2" siphon line? I have a 1/2" fitting on my pump for cooling and am thinking i can split it off into two 1/4" lines once in the engine compartment for dual cooling. Then take the old cooling line and use it to hook up the stock siphon.
Anything wrong with this setup?
NY
this is on an X2. The fitting for the hose at both the engine compartment and pump compartment is 1/2" Does anyone know if the inner tube is that large as well?
