- Asheville, NC
So, I’ve been using this trailer for about 10 years and recently the tires started to wear just the inside of the tire. Both sides but the drivers side is definitely worse, From my research this indicates incorrect camber or an overloaded axel. I just wanted to get some opinions before I spend $250 on a new axle. One other thing I noticed when removing the axle is that the leaf spring bushing is worn badly and was allowing major play for the leaf. Does anyone have any suggestions, Should I try to just replace the leaf bushings before buying a new axle? Tire pressure was correct and checked regularly, bearing preload was correct and also checked regularly… bearing still feel smooth and appropriate. All that being said, the trailer is a 1997 and was originally for a single couch… maybe it’s time for a refresh?
