ultra 150 help!!!!!!!!!!!!
so ill tell you the story about my 1999 ultra 150 before i tell you what my problem is and mabey that will help to acess the problem. so my buddy works at a pawn shop and knows that i mess with skis a little bit. he called me up one day and told me they had a ultra 150 for sale for $1000 he said it only had 47hrs had one bad cylinder. so i thought cool rebuild one cylinder and get it on the water. so i went and bought the ski but before i bought it i did a compression check and it had 120,0,120. i got it home pulled the motor and the piston, head, and jug were screwed. so i got a used pistion, jug, and head with 40hrs on them. then i decided to take the bottom end apart to make sure there was no metal in the there and when i took the crank cases off the engine would not turn over
(it worked fine when i did a comp check)i sprayed it with wd40 and worked it back and forth and it finally came free but it was rough and there was one spot it would stick and i would have to to push harder. then i sprayed it with 2 cans of carb cleaner. i thought mabey it might have some little pieces of metal in it and that would get them out. then the engine finally started turning over great (weird just all the sudden). them i put it all back together and all the comp was good 120 in all three. so i took it to the lake today and i drove it around for like 3 min while i was waitin on my buddy to get there and i helped him unload his ski then when i went to start mine up all i got was a grunt from the starter. after like 15 min i couldent get it to work. all the connections were good and its a new battery. so what do you think? is my bottom end screwed. oh yeah also the motor was really hot. not sizzling water hot but still hot enought to burn my hand. is that normal to
professor961
Selling all X2 and 650 parts - message me!
So the engine turned over fine while you were doing your initial compression check with the bad middle cylinder. Then while replacing the middle cylinder you ubolted the lower crankcase half from the upper and it wouldn't turn over?
First, if you are doing a compression check, also perform a leak down test - if the engine is that new, and holds air, there is no need to disassemble the crankcase. Then, while disassembling the center cylinder, if all you find is a seizure and no broken pieces, then you have no reason to believe a foreign object is in the lower seciton of the engine.
Sounds to me like the engine suffered an event and the engine then sat. The rings stuck to the cylinder walls, then you got them loosened up.
I would reassemble the engine, use new crank seals since you busted into the crankcase, and peform both a leak down and compression check. Once you are sure it is airtight and can make power, then install it and run it.
Your cooling issues are basic - you need to assure the lines and passageways are clear - find the blockage and correct it.
Prof
