SX/SXi/SXi Pro two outlets from 750 head?
what to do with second outlet from head?
  • connect to temp sensor and factory pisser
    Votes: 0 0.0%
  • take overboard via new pisser
    Votes: 0 0.0%
  • block off
    Votes: 1 100.0%
  • other (comment in thread)
    Votes: 0 0.0%
  • Total voters
    1
  • Poll closed .
tor*p*do
Squarenose FTW
NW NC
I got this motor and pipe package to repower my 750 from a board member
there are two cooling outlets on the head, oner for pipe and one for ..
a. connect to temp sensor and factory pisser
b. take overboard via new pisser
c. block off
Thanks!
tor*p*do
Squarenose FTW
NW NC
there is already a outlet off the pipe on the bottom of the photo
that will take water overboard
I dont need dual cooling, it never gets that hot here air/water
I am leaning toward oem connect
other than the thought of running a water line to my ebox:439:
I don't know a lot about his but.... your head is tapped for dual cooling as stated above. If you don't want to run dual cooling then you could block off this second outlet and it would work the same as stock.
You could run this to an over board pisser but then your pipe would be getting less water which could be an issue. Though on the other hand it could be good to dry out your pipe as long as it doesn't over heat.
You could combine the two head outlets together before they go to the pipe. This would allow the stock amount of water to get to your pipe but allow for more evenly cooling of your cylinders.
*these thoughts could be flawed but they are just ideas to think about.
