Super Jet turfing with footholds???
okay i have heard that if u heat up hydro turf you can get it to stretch enough to cover all the area around the foot holds, but i dont want it to have that stretched look
i was looking at just getting sheets and doing it from there. whatever way is better
the more seams you have the more points of entry for water and rubbing points to wear down the contact cement. the turf may peel up in those locations... you jam your feet into the footholds all day long...
i try to turf in only three sheets. sides and bottom. it wont strech that much if you leave enough turf on the sides to work with to go up under and around the shape of the holds...
