Other Turf
Has anyone tried hydroturfs precuts with their psa backing? I've always glued myself bc I'm just a paranoid OCD freak and hate when corners lift, I'd put ca on the edges anyway but was just curious about cutting time out but usually that means sacrificing something some where.
I'm curious about this too for my 96 SD Xp. Seems like it'd be much easier to peal and stick than try to figure out where to mask/paint adhesive on the hull (turf is precut, so that's easy). Any suggestions on prep for the self-adhesive? Just wipe down with wax and grease remover?
I would deff rough surface a bit, clean with acetone, but like you said would be nice to just peel and stick, I mean peel and stick, lolol stick and peel is for a diff scenario.
