Tuning help on a 92 750 SX
So I have this ski I've been sitting on for 4 years and finally putting in the effort on getting it to run perfect. It was rebuilt 3 years ago with SBT pistons 1mm over bore, have now run approx 25 gallons through it, most of it this year. Head is shaved .040 (that I know of as it's stamped on it), 150 psi per hole, stock exhaust, R&D intake with a SBN 44 mm mikuni (which I bought used and literally bolted it on with minimal tuning till now, I was told it came off a 750 but don't know for sure, seems like it could have been a factory Yamaha carb as it still has a choke plate) R&D timing advance. Out back I'm currently running a 9/17 skat trak big hub swirl, jet dynamics scoop and an extended ride plate.
Anywho it runs decent overall, except I seem to have an issue with it loading up at times. I should note I had to go to a BR9ES plug as a BR8 for whatever reasons I would get pre ignition on a hot motor and shear the key for the flywheel on startup, part of my problem. Goes ok with the br9 BUT on checking plugs they look cold. It gets shell v power and amsoil at 45:1.
My main jet is a 130, H screw turned in all the way. Pilot is a 112, screw at roughly 3/4 (seems very close for off the line starts it gets out of the water nice). Silver spring, unsure of needle and seat bore but it's in good shape and my pop off is set to 40 (seems high?)
ANY help would be greatly appreciated!! I plan on ordering a smaller main jet, but not sure if I need anything else??? I was running a Solas SC-I 14-19, but it felt like the motor was having trouble turning it, even though I could go 45 mph.. Since the timing advance went on it feels fat on acceleration, though I read that's normal.
I should also note that I am at 700 feet elevation, as I know that definitely makes a difference. When I started with the ski I was at 2400, which is where I was shearing flywheel keys... I've yet to try a br8 at this elevation.
This is what my plugs looked like before the advance. I've only run a tank since I put it on.
Pop off should be around 20 PSI, get yourself a 2.0 N/S and 65G spring which i think is the black spring. My 650's run 145 main with a 120 Low speed with a SBN44. High speed screw at a little over one turn out, Low speed just under a turn out. If i was you I would start at 145-150 main jet, and 122-125 pilot. I also run BR7ES plugs and the 650's rip!
Got it figured, had to go with BR8's, reason it ran like a dog with them is my hood seal was leaky and Id get water in the motor... Added foam under the hood where it meets the seal and scrapped the K&n flame arrestor for a different one with no filter media and problem solved! Runs like a top now.
