- Edmonton, Alberta
I’ve only had it in sand a couple times and it can take a bit to push or pull the cart which also depends if you run two or four wheels.
The only down side to these is they don’t have a handle on the front to grab with a couple guys or yourself to pull. But I’ve made one for mine to make it work.
I also have a factory zero cart that I can use to go from the deck cradles to the water if I’m at a race. If I’m going to the lake for a day I don’t need the wheels or cart.
