BK you think a "HumpHose" is enough ?You need something to create a hump in the hose so water cannot backflow......
Looks like the box is laid over on its side a little bit. Orient it vertical with a hump hose after the box and I think you'd be ok.BK you think a "HumpHose" is enough ?
thanks!Looks like the box is laid over on its side a little bit. Orient it vertical with a hump hose after the box and I think you'd be ok.
