- Soddy Daisy TN
Hi all. Long time lurker, first time poster.
I finally bought my first stand up ski earlier this year (2009 superjet). The guy I bought it from had only had it for one summer and only ridden a handful of times (it was his first stand up and it was "too much for him" which is why he was selling). According to him he was the second owner (bought from the original owner). It has a factory b pipe, protec half girdle, blowsion arrestors, msd ignition, etc. but he also mentioned to me that the original owner had some group k work done (he didn't have any documentation or anything but there was a group k sleeper sticker on it so I assumed that might have been the kit that was used). The guy said he had always run pump gas (92 octane). Ski had great compression (185 psi in both holes) when I bought it and ran like a scalded dog. I used it probably a dozen times this summer with no problems until recently. It started running really rough (like it was on one cylinder) so I did all the normal stuff (new plugs, etc.) but that didn't fix it. Did another compression test and this time the rear cylinder wouldn't build compression (barely moved the needed on the compression gauge - still 185 psi on the front cylinder). Pulled the head and found this mess.
Broken ring, partially melted piston (all right at the exhaust port side of the piston). The head is shot too as the broken piece of the ring got smashed around inside the combustion chamber.
I did some measuring with calipers and it turns out this thing was a 760. The internal cylinder bore was about 84.5 mm. The top of the piston also had a 50 stamped on it which I'm assuming is .5 mm over 84 mm? So now I'm thinking the group k mod was really a big bore "hammer" kit, which according to their website includes the following and requires running 96 octane:
HAMMER" 96 OCTANE kit components
Cylinder porting & decking
Cylinder boring, hone, & chamfering (one oversize)
Cylinder head modification
Carb boring & circuit upgrade
Hammer cooling system upgrade and by-pass
Ignition flywheel lightening (-.4 lb.)
Rev limiter modification
Case porting and matching
ENGINE PARTS
"Factory pipe" exhaust pipe with exhaust manifold (all models)
Boyesen reed stuffers
R&D flame arrestor
753cc - 781cc Sleeve & Big Bore Kit (All)
Cylinder boring, Porting, Modify cylinder head dome, Piston Assemblies, Gaskets, Bore cylinder & install sleeves (send cylinder, cylinder head, and top case)
I've got a couple of questions and also looking for what to do going forward:
- Could running pump gas (92 octane) with this mod be what caused my failure or is there something else going on that I need to remedy prior to repair?
- How can I get this thing back together? As you can see from the pics above the head is shot. I have purchased a stock head but according to the above group k documentation the head would have been modified during the kit install. I'm assuming I would need to send the new head to group k to have similar work done? I'm also unsure about which gaskets to use on the head and cylinders...
- The cylinder walls look great - I haven't measured them out yet but assuming they are all in round/in spec/etc. could i just drop a new set of same size pistons in after a good cylinder hone (not do an overbore?)
- anything else I haven't considered?
Thanks in advance for any advice. By the way - i am strictly a recreational rider if that matters
ENGINE PARTS
R&D flame arrestor
