- Orange County, CA
Hey Guys and Gals,
I did a search, but didn't come up with anything.
So, I have an '06 Superjet with a built engine.
It has a 61X Cyl that has been bored to about 83mm. I talked to my engine guy and he said that it can be cleanly bored to 83.5mm.
So my question is: is it safe to bore a 61X sleeve to 83.5mm or 84mm?
I have heard that the bottom of the sleeve and break off if you overbore the cyl too much. I read on Group K's website that you need to resleeve at 84mm.
ohh and the cyl is ported too
piston options
ProX makes up to 83mm (no go)
Wiseco makes a to 84mm (could do it)
Pro-Tec makes a 83.5mm (will it break my sleeve?)
so do you think I should go to the 83.5mm or 84mm and preserve the porting or spend the extra $$ to resleeve it and match the porting
thanks for the help
piston options
thanks for the help
