Other Timing, sound waves in expansion chambers..
I found this article and it was extremely helpful to me. It gave me a better understanding on timing, and what timing retard at higher rpm does. May be helpful to some. Here is a copy and past from that website:
Combustion of the fuel/air mixture does not happen all at once like an explosion does. It happens as a progressive burning of the fuel, starting from around the spark to the outermost combustion area. When the spark happens in relation to crank degrees before top dead center (°BTDC) of the piston is something that needs to vary according to engine rpm so that maximum combustion pressure of the burning fuel/air mixture happens between 15 and 20 degrees after top dead center (ATDC). That is necessary for the most power to be transmitted to the gears/sprockets/tire. As engine rpm's increase, the amount of time from the piston being at a set amount of °BTDC to being at top center decreases. But the amount of time that the fuel/air mixture needs to burn remains the same (with the exception above 7000rpm when the extra turbulence caused by the squish band shortens the time needed to burn). Going only by this aspect of combustion it would be ideal for the CDI to increase the °BTDC of the timing as the rpms increase, in a linear fashion. This is more or less true for a 4 stroke engine, but for a 2 stroke there are other factors to consider:
1. Since a 2 stroke has combustion once every crank cycle (whereas the 4 stroke combusts once every 2 cycles) then the pistons top temperature can get high enough to melt it at high engine revolutions with the timing advance equal to that of a 4 stroke engine.
2. At high rpms the delivery ratio of fuel/air becomes less and the pumping loss of engine power becomes more with increased timing avance so that it is accumulative enough to weaken engine power at high revs. "Pumping loss" refers to the power detracted from the engine because of the force needed to push the piston up to top center against the pressures of the compressed gases and the pressure caused by gas expansion due to combustion.
3. Making the ignition and combustion happen later at high rpms increases the powerband of the engine equipped with an expansion chamber because the exhaust exiting the exhaust port is still burning and is therefore hotter than it is at lower rpms. That increased exhaust temperature allows the pressure/sound wave to travel faster. A pressure wave that returns to the cylinder sooner than normal better matches when the piston upstroke happens to prevent loss of fuel/air charge out the port. That in effect it allows a wider powerband of engine power.
The following is from Eric Gorr's paper "Basic 2 Stroke Tuning" where he talks about advancing or retarding the whole ignition curve of an advancing/retarding CDI on a dirt bike by changing the stator position CW or CCW:
AFFECTS OF THE IGNITION TIMING
Here is how changes in the static ignition timing affects the power band of a Japanese dirt bike. Advancing the timing will make the power band hit harder in the mid range but fall flat on top end. Advancing the timing gives the flame front in the combustion chamber adequate time to travel across the chamber to form a great pressure rise. The rapid pressure rise contributes to a power band's "Hit". In some cases the pressure rise can be so great that it causes an audible pinging noise from the engine. As the engine rpm increases, the pressure in the cylinder becomes so great that pumping losses occur to the piston. That is why engines with too much spark advance or too high of a compression ratio, run flat at high rpm.
Retarding the timing will make the power band smoother in the mid-range and give more top end over rev. When the spark fires closer to TDC, the pressure rise in the cylinder isn't as great. The emphasis is on gaining more degrees of retard at high rpm. This causes a shift of the heat from the cylinder to the pipe. This can prevent the piston from melting at high rpm, but the biggest benefit is how the heat affects the tuning in the pipe. When the temperature rises, the velocity of the waves in the pipe increases. At high rpm this can cause a closer synchronization between the returning compression wave and the piston speed. This effectively extends the rpm peak [power] of the pipe.
