i never used a template on any foothold install. position them where u like them and start cutting till they fit, use a wire brush attachment on power drill for fast foam removal.
Thats what I did on my first build, but the thrust holds have the curve on the back edge to match the contour of the hull/QUOTE]
so do the kicker footholds but the curve isnt necessary
but there is noway to get the curve out unless you cut part of the foothold out
