Ocean Pro 650sx :261:Why?
What manifold is this?
get a jss one... They are huge. I ordered a few a couple months ago.
Nice pieces too, make sure to ask john for the yellow urethane its very stout.
I like the clamping version better. I just put a set screw type on my 07 build and if you ever want to adjust your alignment it keeps falling into the old "scar" and it makes minute adjustments near imposible without deburring the shaft or rotating both couplers to a clean mating surface. You also get better/more mating surface area on a clamp type.Should I get the clamping hub or the set screw hub?
get a JSS one... they are huge. i ordered a few a couple months ago.
nice pieces too, make sure to ask john for the yellow urethane its very stout.
you just buy the "shaft part" longer than needed and cut to fit.
