1st- Ive added dual 44's and they each have there own "pump" so im guessing i need to tap a 2nd vac. line in to the crank. True/False? also what size of fitting do i use, its a 1/4 line if im not mistaken
2nd- What size fitting do i use for the dual cooling when i tap the pump?
3rd- This blocking the crossover with epoxe, I know what the crossover is but what are the advantaged/disadvantages, and why is it there? is it just for smoother idle? Im a little confused with this subject:thinking:
One month left then riding season starts, I sure hope i can get it all done !
