Is there anything other than the 20ish screws on the back of the box holding it together?
onesojourner I use a thumb throttle. Location springfield, mo Aug 6, 2008 #1 Is there anything other than the 20ish screws on the back of the box holding it together?
tor*p*do Squarenose FTW Site Supporter Location NW NC Aug 6, 2008 #2 suction from the old rubber gasket is about it should come right apart chuck up a philips head bit in your drill for quick disassembly and reassembly
Mouthfulloflake ISJWTA member #2 Location NW Arkansas Aug 6, 2008 #3 its a bear, a bagrillian wires and crap to stick it back together... Id rather pull an engine than open an E box.... thats just me though...
SXIPro JM781 Big Bore Location Here on the 'X' mostly Aug 6, 2008 #4 I think it is 10 times easier to open the box than to remove it from the studs/bolts that mount it to the ski. Damn things might as well be welded on.
