Freestyle Tail cone removal??
How do I remove the tail cone from a stock wave blaster I pulled the bolts out and couldn't pull it off? Is there a way to do it without removing the pump??
Sent from my Z932L using Tapatalk
Christian_83
Xscream
Denmark
you can wiggle/tilt it a bit (with all screws out) and then put and tool in the gab you created and then wiggle/tilt it to the other side - if this makes sense. Worked for me.
Okay I didn't walks break anything last night so I didn't pry on it but I'll give it a try when. I her home today! Thanks
DAG
Charlotte, NC
you still have to be careful, take your time and pull on each bolt hole in rotation a little at a time
