- Grand Rapids
T3 Performance, is excited to announce the first of many products, and modifications to the industry. After over a decade of testing, the time has come, to finally release our fuel rail to the general public. This product is proudly made, and installed in the USA with quality and dependability at the highest of levels. This product will be offered in a few different options and tiers to fit any customers needs.
Fuel Rail Benefits:
-Simplicity, and reduced time for carb tuning (install and removal), not needing to remove or compromise fuel lines during such process.
-Added ability to easily adjust fuel pressure at the rail.
-Reduction of problem causing variables/ parts within the carburetor (simplifying)
-Cleaner more organized engine bay, with added billet aesthetic
Our Product Will Be Offered As Such;
Fuel Rail Install Only:
-General carb inspection
-Fuel rail install and setup
*customer will need to supply fuel line, fuel filter, fuel pump and hardware and other parts for installation*
Fuel Rail Kit:
-Oem Mikuni high flow fuel pump
-Fuel pump mounting hardware
-Oem style fuel line
-Fuel filter
-Zip ties
Full Fuel Rail Kit And Service:
-Fuel filter
-Zip ties
-Full carb inspection, clean, rebuild and linkage synchronizing
-Carb base and speed plate, decking using surface plate
-Carb spec sheet including, jetting, N/S spec, and pop off readings/ verification.
Extra's And Options:
-T-handle install
-Billet throttle wheel install
-Billet speed plate install/ setup
-Billet flame arrestor adapters, install
-Boyesen manifold kit setup, and install
Coming soon:
-Complete carb packages
-Kawasaki fuel rail support
-66e based fuel rail support
-Special Anodizing of different colors
-Vapor blasting, and ultrasonic cleaning
Order here: T-3performance.com
*Customers will need to remove carbs, drain, wrap and ship to our workshop, then after we finish installation, we will ship carburetors back to customer. Lead time should be 2 weeks after we receive carburetors, and will adjust or notify customers if this changes. We are not in control of the stock of certain added option or products so please be respectful if we are not able to offer them at that time. Pricing may change over time as supporting products may change in price.
Fuel Rail Benefits:
Fuel Rail Kit:
-Fuel filter
-Zip ties
-Fuel filter
-Zip ties
-T-handle install
Coming soon:
