SXR Prop choice?
SXRguyinMA
Life's a beach
Leicester MA
I want to get a prop for my SXR. I plan on doing freeride/freestyle, and want max bottom end thrust. Motor is stock with a 6º ign advance and baffles pulled from stock airbox. I'm about 215lbs, and just chopped 15-20lbs off the ski with hull/pole mods. Any ideas? What works? Pitch? Cutback or no?
Any ideas are useful!! Thanks!
Tuscaloosa, AL
solas dyna fly from impros repitched to 13-21 with 5mm cutback.
or a skat C75 13/18
you can also send your stock prop to IMPROS and get it repitched to 13/17 and remachined and cut back for about $90.00. Great improvement, honestly, not much difference than a Solas or Skat prop.
Bigfish
Bigfish
North Carolina
I ran a 9/17 skat-trak swirl c75 w/ a 5 m set back wet wolf cone 80 m nozzle. Had great bottom end w/ a pipe, 180 psi & flywheel last year. My girl's boat had about same mods except she had 13/20 solas w/ 5 m & ended up switching hers to 9/17 b/c she liked the hit off the bottom like mine. Her boat was just a little faster up top w/ the 13/20 but all around better for surf riding & playing around w/ the 9/17. I weigh 250 & the 9/17 is a great prop in my opinion for the SXR.
Scorn800
Ride for life
North NJ
I run a Skat 9/17 c75 mag prop, with TBM cone, 80 noz. on my wet piped boat.
Pulls real nice off the bottom and tops out at 7200 rpms
