i have just tapped mine in the boss next to the steering cable ,it is tight but possible, i shaved a bit off the boss and tapped it so the fitting went to the end of its threads and cut the excess inside the pump off. i angled the fitting up at 45 degreesso it goes above exit nozzle to the original water out tube.i think its best if you can get the hose to rise all the way especially if you ride in the sea so no debris can collect in any of the hoses.
regards Neil
